I knew of someone who had water running out of the aerial plug. This was because the protective cap over the connections on the aerial had come loose and the box filled up with rain. This then flowed down the inside of the air-spaced coax aerial cable and dripped out of the back of the TV!
She had called a plumber because her TV was leaking...
