In going from the existing low level cistern type loo to a close coupled I am going to have a prob connecting to the existing water feed. Pipe is high, comes out of the wall exactly on a soldered bend and points wrong way.
Will somehow reroute the pipe to a lower position and ensure it can reach a straight or elbowed service valve to cistern
I am assuming that putting a compression fitting behind even a plasterboard wall is illegal and iffy??
The boxed off region behind the loo contains the soil pipe and waste pipes and the the cold feed comes into the box from the left (as you look at it) from the top copper pipe you can see and bends a right angle to come back out the box to reach the loo.
Is my only option to bend a new right angle pipe and compress join this to pipe before it enters the box and push it thru wall just behind loo in position I want???
stopcock doesnt go off completely so any small chance of soldering to existing old nasty pipe is slim.
p.s. dont ask about getting another low level loo. I have tried that one.
heres a pic, I know you love em
