- Joined
- 19 Jul 2007
- Messages
- 5,941
- Reaction score
- 1,139
- Country
Correct.
Will I need an insert also or is it likely to be strong enough? Or perhaps when I get it off I will see if an insert was previously used?
And I take it there is no way either a 20mm stopcock or 22mm isolating valve (both of which I've got) will fit ? The diameter is about 21mm. I'm just afraid about how long it will take to get the correct part tomorrow - already taken a morning off work.
Thanks Spraggo.
I guess I'll need to remove the old olive and nut from the pipe? Maybe if I can't fit the 20mm olive over the pipe I should put the 22mm olive (from the other stopcock I have) into the 20mm stopcock ? Or perhaps sand down a bit the pipe ?
Sorry for all these seemingly daft questions !
So I should be able to get the 20mm olive on the 21mm pipe? Perhaps with lots of wd40 ?
