20mm Mdpe pipe from the street is usually sufficient, however going bigger costs little more as the cost is in the dig.Would there be a whole lot of sense in installing a 32 mm pipe outside and leaving the 15mm inside the way it is?Could someone tell me more or less how much could cost me to updated the mains and what that does it mean to updated the mains?
Many thanks
A new pipe is laid from the street....
Maybe, maybe not. Bit pointless though to do only half the job.ok if I ask to changed my pipe to a 32 mm and do not touch the one inside my house Will be able to have two showers at the same time??
The boiler does not support waterflow, period. It's like a car driving on a road; the road can be too small for the car to reach topspeed, it can never be too wide.Just wondering if the boiler will support more water flow
It is impossible to say what you need to do exactly in order to get 2 properly working showers without seeing the situation and doing taking measurementsBengasman;
Are you saying that I need to replace the pipe in my house to a 32mm in order to have 2 shower as the same time?
I need to clarify that so I can have a clear view sorry for my lack of knewloged
Nope, it means that you have a flow restriction somewhere....If I open the shower tap and then open the hot water basin tap the pressure on the shower goes down quite a lot it's that mean not enough pressure (I think so..)...
