- Joined
- 5 Nov 2024
- Messages
- 6,174
- Reaction score
- 2,942
- Country
It’s possible, or something else if they didn’t touch inside. What type is outside?Tap washer in the outside stopcock?
Type with a black key handle, and a round digital display meter. My neighbour has no water pressure issues at allIt’s possible, or something else if they didn’t touch inside. What type is outside?
I only have boiler cover and I have a feeling they'll come back and say 'nothing wrong'You should get British gas back to sort out the problem they appear to have created.
Could a leak be causing a low flow?You obviously do have something wrong, and since the worked on your system. Your suggesting it even affects your hot water flow from the boiler - get them back, to take responsibility.
Reading between the lines, it's your flow, which is poor, rather than your pressure - the two are different..
Wonder if I should watch the meter see if there's major change overnight?
My meter hole is clear, tap is a threaded open and close, is fully open.Possibly, but it would need to be quite a leakage, and it would show up. Any leak, from what BG had done, would either be inside the house, of at the outside stop tap. You could take a peek down the stop tap hole perhaps, and see if there is a leak there. Whilst there, you could check if the valve had been fully opened. If it's a plastic square, it will have a line across the square. The line should be inline, with the pipe, if it's fully turned on.
Meter read 189768 last night.
Few toilet flushes and some hand washing, tooth brushing and this morning it reads 189793
Doesn't seem like a leak is causing the issue?
Tap washer, meaning 'in a tap'?A tap washer has been disturbed, and is partially blocking the flow.
Got it thanks, so it's either on my outside (road mains) or my inside stop tap (which wasn't touched) so I'm leaning to road mains?... Meaning I need to connect with Thames water?Tap washer, as in stop tap, as in your supply pipe, as it seems to affect your entire water supply.
