Water settling on concrete in front of garage- no drainage!
7 Aug 2004
As per title really- god knows what the previous owners were doing, but in my back garden when it rains the rainwater congregates in an attractive puddle outside the whole length of the garage door. It looks as if they had tried to drill some holes in the concrete without much success- so what i have to do at present, is sweep up a 6' slope, and brush the water into the drain that the kitchen and guttering uses. So, what are my options, I assume I will need to get proper drainage installed?
cheers
Dan
dancleary
yes .. many companies do surface drain soakaways ,your local building merchants will have these channel soakaways
Thanks for the reply Moz. Any ideas re estimates? I would probably need the 1m channels putting across the length of the garage door- the drain that the sink/washing machine feeds into is approx facing the garage 5m away.
Cheers
Dan
dancleary
I dont know about estimates ....sorry ...
if the side of the drive is soil/lawn .. you can drain it there ... :)
hi u shouldnt really put surface water in a dirty water drain . It should run into a soakaway in garden somewhere 5 m away from buildings-
check your water bill. a lot of people pay their local water company surface water handling charges wether their storm water drains into the sewer system or not. building control would sooner your storm water drained into soakaways, but certain conditions determine that your storm cant go anywhere else other than into the sewer system.
any work involving underground drainage is subject to b.c. inspection.
