Hi just wondering if some can give me some advice on my foundations.
I'm building a garden office at the start of next year and will need to put in some 800mm -1000mm deep footings, however I have noticed if you dig below 700mm in the area the footings need to be you hit water and the hole will fill up with about 200mm of water over night, now is this a problem?? Or normal in some areas? My plan would be to dig a hole in the corner and put a sump pump in to pump out the water just before the concrete is poured, obviously building control will inspect it first but just wanted some reassurance its normal or am I going to have an expensive problem on my hands...
Kind regards adam
Kind regards adam
