- Joined
- 13 Jun 2009
- Messages
- 2
- Reaction score
- 0
- Country
We've got water flow issues up our fields, they are so far away the pressure isn't enough, but it does flow. So I want to create a buffer system, by having a reservoir that feeds the drinkable water tank.
The reservoir tank + lid, doesn’t have any holes in it, so I need a fitting for it, which is where I’m stuck.
I’m guessing I would drill a hole in the bottom of the tank, and then add the fitting which would clamp onto both sides of the material to create a seal.
Is it an Essex Flange I’m looking for? I do have access to the inside, as I can actually stand in the tank, it’s that big.
We use this blue pipe everywhere:
http://www.screwfix.com/prods/83620/Plumbing/Water-Pipe-and-Fittings/MDPE-Blue-Pipe-20mm-x-50m
So I’m guessing the outlet from the big tank would need to connect to this threaded fitting:
http://www.screwfix.com/prods/58422...gs/JG-Speedfit-Bsp-female-Adaptor-Blue-20mm-x
Which would then connect to another threaded fitting on the water trough.
Any ideas where to get something that can do the job?
