I'm trying to route some 1mm twin and earth cable across about 5ft of the the ceiling of a ground floor utility room. I have no access from above so my only option is to go across the ceiling. My goal is to hide the cable as much as possible and therefore I don't wish to surface mount or use mini-trunking etc.
The cable needs to run against the direction of the joists and three are in the way. The joists are wood and about 2 inches wide with about 14 inches in between each one. I wondered if anybody has any good ideas as to the least disruptive way of routing the cable. I had thought of using a cutter to make an access hole mid-way between each joist and then using a long reach wood bit such as this : -
[url]http://www.screwfix.com/prods...Bits/Bosch-Self-Cut-Flat-Wood-Bits-22-x-400mm
to make a hole in each joist through which I could route the cable, with the help of bits of wire / string etc.
I'd only be left to make good the holes in the ceiling then the job would be finished......anyone have any other ways they have tried....
Many thanks - 3george...
[/url]
[/url]
