Whenever either hot water or heating is demanded the boiler kicks in, the pilot ignites and then the burners light also as expected. Howver then almost instantly the burners go out. The boiler continues to whirls and the burners light again, but then go out. This process will just continue until the demand is ended. The reset button does not pop. The pin in the diverter is in the correct position (out for hot water/in for heating) and is steady. The diverter was replaced about a year ago. So I can't think any other things to check that would cause this problem? Any ideas would be appreciated? Thanks in advance.
