I've just had this system fitted and the last couple of days have been using it as the weather has turned a bit cooler. I've noticed the rooms take a while to warm up, longer than I was expecting and I've been looking at what the controller is doing.
It has set the desired flow temperature according to the outside temp and this more or less agrees with the curve for radiators in the manual. (10deg outside, 38deg flow temp.)
HOWEVER, when I watch the actual flow temperature on the info screen, it spends most if its time well below this desired temperature, in the low 30s. Occasionally it goes up to 42deg or so and then immediately starts dropping.
Is this normal or is there a problem somewhere?
