WC Waste pipe
27 Mar 2005
Just fitting a new WC. The distance from the wall to the end of the WC waste outlet is 165mm, but the distance from the same wall to the soil drain is about 190 mm. By the time I put the 90 degree outlet pipe on the pan, then the waste will miss the drain - not a good idea!!
Is it possible to fit a "flexible" 110mm waste pipe, like a sink outlet, so I can attach the cistern to the wall, rather that stand the whole thing off the wall by about 6 inches. Sorry about metric and imperial.
try a swan - neck pan conector that might do it.
That might do the trick.
Cheers I will let you know.
Any idea on a supplier, or just try B&Q?
support your local independent plumbing merchant, their prices and advice are much better than the "DIY Sheds"
Brumylad
I take your point and chat to the local trader rather than the profit maker!!
Regards
Bob
