I'm replacing a combi with a system boiler, I've already had the hw cylinder and zone valves installed and was thinking about a weather compensated boiler since they're apparently more efficient.
I was looking at a Viessmann boiler, as it comes with compensation built in (just add an external sensor) but I see it has separate flow and returns for the DHW and Heating. Unfortunately, I didn't get separate f/r installed for the cylinder and now it's occurred to me that when the boiler flow temp has been lowered by the compensator the cylinder won't heat up as quickly, if at all.
Vaillant do a system that has a hugely complicated clock arrangement that basically seems to override the compensator during the DHW periods, so it essentially runs at max temp. The boiler is in the garage so I don't want to keep going out there to change the time program whenever I want hot water out of the normal periods
Given that I've messed up the pipework I guess the next best thing I can do is have the boiler run at max temp when the DHW is calling and be compensated when doing Heating only. I can achieve this by controlling the Viessmann from the heating zone valve and disabling the compensator with the DHW zone valve but it seems a little Heath Robinson -ish (I know it's more complicated than that but I was a sparky in a previous life, I can manage it).
My question then: Can I get a boiler that will accept two start signals, one to run at max output, one to run with weather compensation? Bonus if it will accept three signals (2 heating / 1 DHW) and run at different outputs (pump speeds?) depending how many zones are calling.
NB Whole thing is only 12KW, so yes, absolutely having two heating zones was overkill, but I could, so I did
Thanks for reading!
Thanks for reading!
