I'm not sure this is the right name for it, as I thought a weather strip was the metal bit in the door step, but anyway, I have one and need to fit it.
But which way round does it go? Its got a slot running on both sides so could go either, but one side is 5.5cm and the other side is 4.5cm.
View media item 6997
I'm assuming thelonger one goes on the bottom?
Also, what fixings should I use to connect it? I was going to drill and screw it??
Also, the door is already painted. Does that matter? should I sand it back first? I was going to prime the weather strip and screw it on, then give it an undercoat and topcoat in situ
