Weeping Radiator Valve
DYS
21 Jan 2008
Dundee
I have a weeping/leaking radiator valve. Is it possible to replace an upstairs radiator valve without draining the system, I cannot find the drain point. Any help would be much appreciated
many thanks
Remove the lockshield cover or valve cover and tighten up the olive. A few of mine used to weep when the system was cold, and this sorted it.
Chris_J - thanks for that but tried with no success.
Would it be possible to tie off the ball valve at the tank, release the radiator and capture water from the radiator. Would this allow gravity release of upstairs water only to allow valve renewal without full drain of system ?
Any help would be appreciated
I'm clutching at straws now ...
Would it be possible to freeze the pipe then replace the leaking valve. Is this reasonably straighforward and if so what do I need.
any advice would be appreciated
thanks
