Was ripping out the bathroom and wanted to put a new bit of 22mm copper pipe onto an old compression fitting. I picked up the wrong compression nut of fitting I'd bought and it would go on. After having a look I found the one that came off the fitting and it had a different number of threads... they were far tighter.
The nut was stamped with 22mm but it wasn't compatible with a standard equivalent. Anyone come across anything similar? In the end the fitting leaked like a bar stud so I cut it out and soldered it back up. But I'm just wondering what I'm missing.
