the flexy hoses that come out of my sink tap has a 10mm nut at the end?, the problem is that it will ot fit on my plumbing, is there such a thing as a 15 to 10 mm compression valve??
If you wish to fit a pair o bollofix vvs ,purchase 2x15 mm & 2x 15mm x 10mm reducing sets or stuff the valves and fit 15mmx 10mm comp straight couplings,or get a new pair of 15mm flexis that screw into the tap bottom.[check size]
