has anyone got any experience of these floors please?
http://www.tilefixdirect.com/category/shower-trays.html
cheers
cheers
basically are they any good?wanted to get a plumber to install the actual tray as i need my bath and toilet moved soil pipe moved and the shower wast run under the floor then lay the floor and wall panels myself and do the tilingYes, doing them on a daily basis at the moment for disabled/old people who can no longer get in and out of the bath.
What do you need to know?
Don’t’ disagree with the joist trim but not too much. If it’s a chip floor I’d take the bloody lot up & replace it, chip of any sort is crap & not a suitable tile base; it won’t last. Size/pitch/span of joists? Replace the chip with what sort of ply? Type/thickness/fixing? Additional support, considering you’ve trimmed the joists & removed some of the strength? It's a wet room floor, what about tanking or even over boarding with Marmox? Type of tiles being used? Tiling materials?I wouldn't go for the tray, if wanting a wetroom take up say 1m² - 1 & 1/2m² chipboard.
Plane the joists down to give a dip in the joists, install the drain, screw plywood down to the joists (the planing should now give a dish floor). Then tile the floor.
Just an idea![]()
Be very careful, less “grief” now very often means shortcuts which, in the (not so) longer term will mean even more grief if you’re around to witness it!had a nother idea which i might do with a shower tray straight on floor will need to sort out costs of both and which is less likely to cause me greif!
