We're currently staying in a cottage in the Peak District. This stupid heating system - Potterton combi and Owl intuition system is useless. No thermostat that you can turn up or down, the 'boost' button in the lounge doesn’t work which means going to the identical button in the boiler outhouse. On top of this, there’s a TRV in the same room as the controller which is fitted about 18” from the ceiling. It’s all controlled by the owner remotely and he says it’s set to what I wanted - a couple of hours in the morning and then 5-10.30 at night. Still useless. There’s a back up fan heater that only blows cold air and a log burner that will burn kindling but not logs! Never had any trouble with log burners but I’ve tried every combination of air vents with no luck. Totally ****ed off.
What’s the point of the owl intuition system - just meanness? Thinking of going home a day early and leaving the hot tap running!
