I'm laying a solid oak floor over conrete sub-strate and cannot decide whether to use Lecol ms250 or ms250+ can anyone advise on the difference and what they would recomend. Are there any websites where I will be able orderonline. Many thanks
You need to do a moisture test first or lay a liquid DPM before fixing directly to concrete. Then you will need an adhesive that is compatable with your DPM, such as F-ball B93. You might also need a levelling screed if you subfloor isn't level within (3mm over 3metres).
