Firstly, what are these vertical (or vaguely looking like they were meant to vertical) bits of wood for ? Holding the ceiling up, or the roof down, or something else ?
Or put another way, can they be safely removed (they are in the way of flooring it), and what needs to go in to replace them (nail rafters to purlin with a short bridging piece ?) if they are removed ?
Also, I believe this is a breathable sheet under the tiles. The ceilings slope down for a foot or so at front and back of the house. AIUI, because this is a breathable sheet, I can fill the whole gap with foam board (ie Kingspan or equivalent) without having to leave a ventilation gap. Is that right ?
I haven't actually worked my way out to the eaves yet (I'm a "well build" chap and been putting that off as long as I can), so I don't know what if anything is already in the gap - I'm assuming decent insulation probably wasn't added while it was being reroofed and it would have been trivially easy to do from above
And for the small gaps (like between the end joists/rafters and the walls where there's no chance of getting anything else in), is is safe to fill with expanding foam (being careful not to overfill
