the electrician isnt registered but his friend is going to sign off work before i pay in full.
Well - apparently his friend isn't going to do that.
Pay in full?
I'd suggest not paying anything.
basically the guys friend came out and said he wont give me a installation certificate as he didnt do the work.
And your original "electrician" must have known full well that that was going to happen.
hell only finish off the bits he aint done and supply me with a periodic inspection report.
Your problem is not one of EIC vs PIR - it's Building Regulations certification.
this guy is also going to rewire my lighting as ive no earth
That has nothing to do with getting Building Regulations certification for the CU replacement.
and has given me a good price. to be honest im kinda stuck as i know its going to be very expensive to get a full installation cert now as that would mean paying council or another lecky.
Assuming the original guy was actually an electrician then he can give you an installation certificate for his work. What he can't get you, as he isn't registered, is a Building Regulations completion notice. Nor, as it turns out, will his friend lie for him and get you one that way.
so will i be ok with just this pir?
No.
ive had few leckys out and they wont at least 100£ more if not more to finish off and rewire lights...
And none of them will lie to Building Control either, so nothing you have anybody do to the lights will make any difference to your problem of no Building Regulations completion certificate for the CU replacement.
ive been told this guy is good from family.
You should have used him in the first place.
Ask him why he won't notify the work that his friend did.
Ask him why his friend said that he would notify it.
Then report
both of them to Trading Standards, and the registered one to his scheme organiser, saying that they are working together with a lie about "my friend will sign it off" which translates to the "friend" trying to blackmail you into having extra work done in order to get the original work "signed off". Doesn't matter if none of that is true - you must have misunderstood, but you might as well stir a little s**t.
will a pir be ok when say 5-10 years down line when i wont to sell
No. Your problem is not one of EIC vs PIR for the CU replacement - it's Building Regulations certification. Assuming the original guy was actually an electrician then he can give you an EIC for his work.
surely it aint gonna be that much grief??
With a genuine EIC from a competent but unregistered electrician the grief will probably be small - it will depend on where you are in the balance between buyers market and sellers market, and how aggressive your buyer is.
A PIR (or actually EICR - Electrical Installation Condition Report now) from a registered electrician will stand you in no better stead - it still won't be proof of Building Regulations compliance.
ill deffo never go with no unregistered low life again my bad ...
Why did you?
Was it because he was cheap, by any chance?
