I'm saying nothing about certificates - the discussion is about 'notifiability'. As I've just written, BS7671 allows (but does not compel) you to use a MWC (rather than an EIC) if you so wish for work which does not involve any 'new circuits'.Interesting if you say you can use an installation certificate even when the work does not involve new circuits?
If the CU is fully populated, all you can do is extend the existing circuits, unless you install an additional (or larger) CU, or some equivalent like a switch fuse - in which latter case it's pretty obvious one is talking about 'new circuits', isn't it?In which case how do you define a new circuit assuming a fully populated CU?
I'm not sure I fully understand, but if you 'share ways', I would call that 'extending an existing circuit'.In the past before Part P I would often use the ways available but if short of room then share ways.
Strictly speaking, that's true - but I think there is usually a common sense meaning of 'new circuit'.I just think Part P is unworkable without definitions.
It's not only an issue in relation to England. Is it your belief that, in Wales, adding a new socket to an existing ring or radial sockets circuits by spurring/branching from the CU is notifiable?
Kind Regards, John
