I have two fuseboxs. Both are outdated and need to be replaced. One is 15amp x 3 only goes on at night. The other is 100amp. Two 30 amp fuses, 1 5amp fuse and one MCB. No RCD.
What else do I need to check to work out what type of CU I need? If I just get a new MK sentry CU or a Merlin Isobar, what are the odds that its compatible?
I am looking for a mid range CU, thats preferably about 10 way.
No intention of fitting it yet, until I am happy that I know what I am doing. Even then would have an electrician to take a look at it afterwards, to make sure it is fine.
I have 1 live and 1 neutral going to the the main CU. I also have 1 live and 1 neutral going to the night economy 7 box or whatever it is. Do most CU have four connections for the four cables from the meter? What type has this. I assume I would not need two CU after I upgrade?
Last question. Since the wires leaving the meter have a current running through them, what is the correct procedure for disconnecting them from the old CU and connecting them to the new CU? As far as I know can't see anyway to shutdown power to these.
