Hi to you all, long time lurker here but first time poster.
I am renovating my 1st floor bathroom and looking to insulate the two brick walls, one exterior (cavity brick, no cavity insulation) and one party.
Although I was initially thinking of using stud work I am now thinking it would be simpler to use D&D with insulated plasterboard.
I’m a little lost on the ‘U number’ I need, and what would be the most cost effective insulation to use. I am also putting a shower in the corner against both the exterior and party wall, so any plasterboard I put in would need to be suitable for tiling and moisture resistence.
To complicate the matter slightly more - there is a false ceiling in the bathroom with an 80cm or so cavity above, with no insulation in it. I think the loft has insulation in the rafters however. I am not sure how or if this matters and if it has knock on implications.
Here is a pic of the room in question, any advice on how to proceed would be most appriciated!
