DHW will in fullness of time, get the same temperature as radiators, there is no way to stop thermo-syphon heating DHW.
The only thermostat on the cylinder controls the immersion heater, nothing else.
The boiler is a simple on/off oil fired boiler, i.e. mark/space control only, as far as I am aware, all combi-boilers can modulate, so they are completely different in the control methods, sorry I should have made that pain.
So yes controls are fairly primitive, C Plan.
When I moved in, I did not really understand how old heating worked at all. My old house was open plan, and it worked, so no reason to play with heating, and two boilers one for DHW other for CH. Parents however had a combi-boiler, with a modulating boiler, and I realised the lock shield valve setting was critical, but the current and target display on the TRV helped set the lock shield valve.
But here, I started again from scratch learning how to set things, with the mirco bore piping the lock shield could be left wide open, the radiators never seem to over shoot, the TRV heads close them down fast enough at times and temperatures set.
The main problem turned out to be the hall cooling too slowly, but until the double glazing was all replaced, I was not sure if the controls would need altering, so this will be first year with all new double-glazed windows. It became apparent I needed a new thermostat in the living room, which kept the boiler on longer, so now three thermostats all in parallel one in hall, one in wife bedroom, and one in living room.
However, the temperature hysteresis needs improving, the TRVs in living room do nothing during the day, they are wide open, only overnight do they close, they are set around 2°C above the wall thermostat.
So I have been looking at the boiler temperature dial, and wonder if adjustment can reduce the hysteresis, but not really sure how it will affect the heating, hence the question.
In summer DHW is solar-powered, using excess solar before exporting in, but winter, I can't stop the boiler heating DHW, the hall thermostat can turn on boiler without the pump to heat DHW only, but that option is never used. There is no option for the reverse, can't turn DHW heating off.
So what will the dial on the boiler do for heating control?
