What flooring should I use in damp area ?
11 Oct 2016
My porch floor is particleboard which is sopping wet, rotten.
it is tiled on top.
I need to replace it asap , I'm not sure why it's so wet.
Maybe I need to treat the joists too ?
If so what with ?
What's the most water resistant ?
Should I replace with wooden floorboard ?
Marine ply ?
Water resistant chipboard ?
Sorry, this might not sound very helpful!
But you really need to sort out the damp problem first!
Ideally you need to understand what is happening; allowing you to cure the problem, or mitigate against it.
Just sweeping the issue under the carpet (or in your case, marine ply ;) ), will eventually lead to failure; then having the expense and hassle of doing it all over again.
I hope that makes sense - post some photos if you can :)
