what fuse
What you gonna be using up there? (TV amp, 8 x 500W sons 8) )
What size cable you using?
length of run?
etc. etc....
Oh yeh, you know a new circuit is notifiable? :wink:
im not sure what size cable to use.
is a 2.5mm Twin & Earth cable ok?
yeah i will be using a tv..etc ete
could i use 2kw heater on a 32amp fuse ?
thanx
It would be irresponsible of me not to mention at this point you don't really know what you're doing. :(
If you insist, you can use 2.5mm on a 32A breaker if it's a ring circuit. You could also use 4mm on the same breaker as a radial circuit. (probably easier for you if you know the difference :wink: )
Either can take a 2kw heater no probs.  8)
Whatever you choose there are far more factors you need to take into account that i can't be bothered to run through here.
I urge you to consult a pro at least even if you don't contract him, if you want to keep things safe in your home.
oh yeh, and watch out for the part P police, what you're proposing needs to notified, tested and certified to keep legal and stop someone frying! :cry:
P.S. Try reading up in the Wiki if you're gonna try this solo.
