what happens if...
24 Jun 2007
Hampshire
... I dont use primer??
The threshold to my built-in wardobe has paint missing where it looks like the previous home-owner has sanded the threshold to accomodate a dropping door, as opposed to just re-hanging the door.
I've now re-hung the door and I'm wondering how to fix the bare patch of missing paint.
After doing a bit of research it appears I should prime the bare wood before applying the satinwood.
But what exactly would happen if I didn't use the primer first? just went ahead and slapped a couple of coats of dulux trade satinwood on instead??
Nothing really, as it's self-undercoating.
that much I know, but then what would be the benefit of priming???
If I dont, is it going to bubble/ discolour/ flake off???
Always prime bare wood... Unless its somewhere you dont see (like an old wardrobe!) or youre about to sell your house :wink:
If you paint gloss , satin, eggshell etc. straight onto bare wood it may peel off , primer is 'designed' to provide a stable base for topcoats (inc undercoat) it has properties that seal the grain & pores of the wood , topcoats need this otherwise the wood will simply absorb the solvents in the paint - drying the paint to quickly and affecting the quality/durability of finished surface...
..ahem 8)
Cheers, much appreciated.
Area not going to be seen.... check.
:lol: Straight on with the satinwood then :lol:
