What is Building Controls' reaction likely to be
11 Jan 2013
Durham
Might be better in building, not sure...
I want to create a ground floor shower/toilet room using the coalhole and a bit of what was the kitchen (usual leanto at the back of a terraced house, 1820, mostly halfbrick walls). Trouble is (having dug out the cobbled floor in the coalhole) I find there's only 150mm between the top of the foundation soldier course and the existing (concrete) kitchen floor level.
Any thoughts on what sort of floor I could construct in that depth that'll work for a shower room (doesn't have to be a wet room) and will satisfy Building Control? Or do I (theoretically) just chuck 50mm of hardcore, a handful of sand, some poly and the rest concrete and say it was done years ago?
Oh yes, and is it standard/acceptable to cast a hole in your concrete to leave space for the shower drain trap and waste pipe? The actual waste pipe from the shower will exit through the wall (rather than through the slab) so it'd be about 200mm square
There's loads of other stuff going on to do this house (moving a wall, replacing a purlin, putting a new back door in the kitchen space, loads more floors to replace), BC will be on the premises fairly soon anyway for a new garage I'm building so I'd rather have them on side for advice but don't want to create a rod for my own back in the process.
Ta everso
As BC will be on site fairly soon, you could just ask them? Most the BCs I've had over the time have been happy to give advice on what they'd accept
Update (for anyone with the same issues).
Wandered in to Building Control and chatted them up- lots of suggestions and their way of dealing with the detail (Part L especially) was 'whatever you do will be better than what is there now, you can't get old houses to comply fully with current regs so we'll have a look and go for what is reasonably possible'
Hurrah.
