I have had some renovations done on an old house and whilst totally unfamiliar with building regulations I believed I was ok as I have not changed anything structurally. I have had electrics re-wired, new plumbing, a new bathroom (no changes to stud walls apart from some plasterboard added to replace wobbly lathe & plaster), sub-floor joists replaced due to damp. The ceilings have been reboarded as the lathe and plaster ones were very cracked/sagging. It is not a listed building or in a conservation area, but is in an AONB apparently.
However I have just had a 2 inch concrete blinding added because the kitchen floor was lower than the adjoining rooms and the tiler also said it was too uneven to tile on. I removed the quarry tiles and concreted on what was there, which was basically dirt. My tradesmen just advised me that a building controls officer turned up saying that he had recently seen a concrete lorry and wanted to know what was going on as there are no building regs.
I was advised by the people who did the floor that because we weren't changing anything but were just adding to the existing floor that I did not need to advise anyone. I have to call him now....Do I have a problem and is there anything I should/should not say? Should i say that I left the tiles in situ, or is this irrelevant? He will be able to see that we haven't changed anything structurally but I am now concerned about the concrete floor.
What's the worse case scenario? I will soon be having the floor tiled and a new kitchen installed, hence my concern.
All advice appreciated before I make that call. Thanks.
