is that in use as in no flamable vapours but when set can burn ??Maybe, but worth bearing in mind that most conventional wood glues break down at 70 to 80 deg. Centigrade (and that PVA is flamable, whereas Gorilla Glue - a PU glue - is not according to the technical sheets)
Who’s risk assessment?It's a rental property so I have to be careful about the fire rating of anything in there, according to the risk assessment.
well the everbuild foming pu glue as you expect has gone solid [non expanded]over the last 2 years off no use so cut off a strip 2 postage stamps in length and perhaps 0.5-0.8mm thick with a normal candle sized flame from a lighter and the acrid smoke whilst under the flame suggests it would not be classified as self extinguishing without flame but off course may perform different if foamed but doubt it ???is that in use as in no flamable vapours but when set can burn ??
i feel an experiment will pu set lump off honycomb and a ronson happening tomorrow![]()
I'm thinking the Gorrilla Woodworking Glue is just a yellow-ish PVA (it possibly has some water resistance). It looks and works just like any other white / yellow woodworking glue. (maybe starts to grip a little too early for my liking) But just a normal PVAMaybe, but worth bearing in mind that most conventional wood glues break down at 70 to 80 deg. Centigrade (and that PVA is flamable, whereas Gorilla Glue - a PU glue - is not according to the technical sheets)
