what kind of beading to use for dry wall
11 Apr 2006
Berkshire
I'm about to dot'n'dab plasterboard to my walls, and fix beading prior to plastering. There seem to be a few sizes of beading around and I'm not really sure which type I should buy.
e.g. this large/coarse type:
http://www.wickes.co.uk/Plaster-Angle-Bead/invt/240320
versus this smaller type
http://www.screwfix.com/cats/101154/Building/Internal-Plaster-Beads
I'm leaning towards the latter as it specifies that it provides a 3mm outstand depth for the skim, whereas perhaps the first type is more suited to external rendering?
Cheers
Gary
It’s the 3mm thin coat bead you need for plasterboard; the large one is for render or base coats. Personally, I still prefer steel beading to plastic & that Screwfix price is expensive; I get mine from B&Q, £1.60 for 2.4 m length or £1.80 for 3m length.
I fix with a staple gun (if you have one) & a few dabs of grab adhesive along each side but you can use plaster.
