What lenght does a catnic lintel need to be
24 Jan 2011
Surrey
As a rule of thumb, by how much does a catnic lintel need to rest on the wall
is it 200mm or 300mm or more
Chris
Catnic selection procedure
Step 2: Structural opening
How wide is the structural opening?
a.Measure the size of the structural opening i.e. the open space between the walls where the door/window frame is fitted
b.Add 150mm minimum to each end
oops red herring has already given you the reference.
Sorry !
The minimum is actually 100mm (under normal loading conditions) but the standard recommended bearing normally quoted is 150mm.
If you can't find reference to 100mm on any of the sites, then you can ask the lintel manufacturer and they will send you this information ... which will satisfy the BCO if need be
