What range of resistance
  • Thread starter Thread starter mo2
  • Start date Start date
This may not be a good idea if the amplifier is fussy about the impedance of the load ( the speaker ) it is driving and the head phones are low impedance ones.
To get a total zero volume you will need to connect it as a potentiometer.
I have very little idea what you mean, but i mean a regular headphone output like an mp3 player. It would go between the ground, so that it controls both channels.
I'd start with a value of 10k and see how it went.
The ground connection just means it's a common connection and when it's all soldered together and a 3.5mm jack plug fitted and your screened cable soldered to the correct terminal in the plug it will be connected to chassis (ground, earth, 0v etc..)
There are devices that are designed to work without this ground wire continuity but thats another story in this case it's needed
But you don't need to fit an earth spike if that's what you mean.
And your further questions yes and yes
