What screws for fixing plasterboard to metal C studs?
30 Aug 2019
I ‘ve started building a decoupling wall with metal studs; I’ve been using these screws for the first sheet (they are self drilling, so they have a small drill bit on the end
https://www.screwfix.com/p/easydriv...ted-drywall-screws-3-5-x-25mm-1000-pack/25899
The problem is that, when the screw meets the stud and starts drilling (it takes 5 to 10 seconds), it also starts working as a worm drive and extracts a lot of powder that ends up below the screw head the moment the metal is finally perforated; also, it tears the paper 90% of the time
Should I use the ‘pointy’ screws instead?
https://www.screwfix.com/p/easydriv...ted-drywall-screws-3-5-x-25mm-1000-pack/48867
Have you considered drilling a pilot hole first?
I have only ever used those screws when attaching plywood to metal framing or when fixing sheet metal to sheet metal. In both cases I found it easier to pre-drill first, actually in the latter case I drilled a clearance hole and a pilot hole
no, I haven’t tried drilling a pilot hole
This guy seems to be using the pointy ones (without the drilling end) and they seem to go in quickly
I’ve used your first kind of screws without problems to fix PB to resilient bars.
I believe you can also use “pointy” ones as long as they are fine thread. The coarse thread ones are for wood.
I don’t know if they will solve your problem though. Do you just need to turn the torque down a bit?
I’ve bought a box of 1000 of the pointy ones and they’re even worse; it takes forever to drill the hole, I’ll be returning the other 999 screws and keep using the first ones
So here’s what happens when I screw 15mm SoundBloc plasterboard to metal studs using the self drilling screws mentioned before
Even before the screws sinks, the paper is already ruined
It doesn’t happen if I screw it to wood (even without using wood screws)
Ok, I’ve found the solution after a lot of trial and error on scrap pieces
I need to sink the screw about the depth of the drilling end bit (2-3mm) with a push on the driver before actually screwing, that way the screws thread grabs the gypsum from the beginning without tearing the paper
