What settings for using drill for screwing?
OM2
18 Jan 2007
On my bosch drill I have 1-5 and that's marked for screwing.
So I set to 4 and keep on power 1 setting. Is this OK? (Referring to the red slide button where you can slide to 1 or 2)
Putting some ikea furniture together, this has been ok 95% of the time.
Sometimes... I've had to change to 10-15 because the screw wasn't going in.
I screw down and wait for the grrrrrr sound.
Am I doing anything wrong?
Probably not - if you're not chewing up the furniture.
You cannot expect all screws into all material to be the same - which is why there are adjustments.
thanks for the replies guys
@ReganAndCarter awesome video. i didn't know the middle things was gear and the twist was torque. i thought the 'middle thing' = more power the higher the number. :)
if screwing furniture, should i be in gear 2 to have lower power?
@big-all - what do you mean you don't use clutch?
you mean you don't wait for grrrrr sound? if so, why not...?
thanks
do it by feel as you get near to the end you slow down you will soon get the hang off it:D
  • Thanks
Reactions: OM2
