RCD yes, must be used for sockets that can reasonably be exected to supply portable equipment used outdoors, as Davy says, this much is required by the regulations
However, I would add all sockets in a kitchen (for when you drop the kettle in the sink or poke a knife into your toaster)
and I would protect all sockets in the house, even if they are nowhere near the garden.
And electric showers.
You might think it would be extra-safe to have everything on an RCD, but this is not true. If all the lights go out unexpectedly while you are e.g. up a ladder, running downstairs, lifting a heavy object or pan of boiling water, putting child into bath, then the sudden darkness could lead to an accident.
It is best not to put electric cookers on an RCD, as they often have slight leakage that causes nuisance tripping. For this reason it is best to have a cooker switch without an integral socket.
the immersion heater should not be on an RCD because it is prone to nuisnace tripping. Central heating boilers and their pumps also often have slight water leaks and cause annoying trips.
The burglar and fire alarms should not be on RCD or they may not be live when required.
If you can arrange for your freezer not to be on an RCD, this may save the food inside being spoiled if you have a trip while you are away (not all houses can afford this luxury)
If you are having your house rewired, and are able to spend extra, you can have individual circuits protected by their own RCBO instead of having just one RCD for the whole house; this means that a fault on one circuit will not cause inconvenience on other circuits, and is an excellent way to do it. For example, I have each floor of my own house on its own RCBO, plus one for the garden circuit.
