    Dismiss Notice
What silicone grease do you plumbers use?
Discussion in 'Plumbing and Central Heating' started by veedee, 25 Oct 2021.
  1. veedee
    veedee
    27 Sep 2011
    521
    Thanks Received:
    13
    Country:
    What product do you swear by?
  2. Sponsored Links
  3. lewib85
    lewib85
    25 Oct 2021
    10
    Thanks Received:
    3
    Country:
    I use poly pipe silicone grease that’s in a little tub, I also use the spray which I use for speedfit fittings but it’s not as good as proper grease. Hunter do a grease which is slightly more runny. All in all it depends what your using the grease for? If your using it for drainage fittings and pipe then I would use the poly pipe grease that’s in a small tub. Good luck dude.
    • Thanks Thanks x 1
  4. veedee
    veedee
    27 Sep 2011
    521
    Thanks Received:
    13
    Country:
    Brilliant. Thank you.
Loading...
Share This Page
