What silicone grease do you plumbers use?
I use poly pipe silicone grease that’s in a little tub, I also use the spray which I use for speedfit fittings but it’s not as good as proper grease. Hunter do a grease which is slightly more runny. All in all it depends what your using the grease for? If your using it for drainage fittings and pipe then I would use the poly pipe grease that’s in a small tub. Good luck dude.
