What size boiler
21 Sep 2009
Yorkshire
I am about to have a new heating system installed, and would like advice on boiler size. It will be fitted in a two bedroom house and will need to run a mixer shower. All advice would be much appreciated. Thanks!
There will be 6 rads and a bath.
The boiler will be in an old coal store under the stares the gas meter is about 2 meters from this location.
Unknow water pressure.
I assume you mean you will get a combi?
If so I would suggest a 28-31Kw model.
Combi's are sized for your hot water use and range rated for your heating.
I would not recommend less than a 28Kw to fill a bath in mid winter.
