What size brads/nails for fixing fence boards?
9 Jan 2020
Got a bit of a fencing job and considering getting a battery-powered nailgun, rather than using screws as I have before.
Various grades around and I would like to be able to use it on other things, I don't want a specialist fencing tool so I'm wondering if a lightweight gun used for internal trim would be adequate? A big first-fix gun would be total overkill, right?
I normally go Dewalt but am considering Ryobi One+ as it won't get heavy use, what length/gauge of nails would be normal for fixing the fence boards to the rails?
For heavy fencing like Norfolk (hit and miss) fencing I would use a 1st fix gun. For lighter stuff I'd look at a 15 ga or 16 ga gun. Nail length depends on your board thickness, but you normally need nails 2 to 2.5 times as long as your material is thick get a good fix, e.g. 16/8mm thick feather edge board overlapped will need something like 50 to 63mm nails
Thanks, I think all our stuff is plain 16mm boards (not feather edge). The Ryobi options are 18Ga (50mm) or 16Ga (65mm) so I guess you'd say even the larger one is really a 2nd-fix gun, the smaller one is just for trim? Sounds like you'd advise even their bigger gun is a bit on the smaller side, and the smaller one is too weedy?
Price difference body-only is actually only a tenner, seems the larger one needs a bigger battery but I'm thinking to get an adapter for my Dewalt batteries as I have several 5Ah ones.
We use 18 ga guns for trim work like pinning smaller mouldings in place (e.g. false panelling on flush doors etc) and where material is pre finished and a loss obtrusive pin hole is required (e.g. oak architraves with a clear lacquer finish). 18 ga has very little structural strength
16 ga pins are quite a bit heavier, but still have limited holding power so must be used with care whereas a 1st fix nailer is often too heavy for the sort of cladding, etc that would have traditionally been done using 1 to 1-1/2in oval nails
