What size ladders do I need?
26 Sep 2008
Staffordshire
My house is about 17 feet from ground to soffit (hipped roof),what maximum size extending ladder would I need to clean out my gutters?(I'm not planning on ever climbing onto the roof).
I don't want to buy ladders too big for my needs because I'd like to change a few upstairs glazing units that have blown too.
What should I look for when buying used ladders?
If 17' is 4x the recommended distance of the ladder base from the wall then you need at least sqrt [(17/4)^2 +17^2] = 17.5' and I like another 3' above to hold onto.
Almost certainly a ladder leveling device will come in handy.
On the basis that you can only reach about 7 feet, and you don't want to be standing on the ladder whilst trying to bounce it up or down the extensions, then you'll probably need a triple 10feet unit. Yes lots of wasted overlap length but it's that which gives you stiffness.
Others will no doubt disagree but that's my opinion - and the length of ladders I have for the same height of gutters.
Er,I'm not sure I understand - you mean 20'6" would be an ideal max length?
I'm not sure what angle a ladder needs to lean at to be safe.
Triple ladders are expensive,I'm looking for the cheapest solution that doesn't leave me in a crumpled heap on the ground.
Will I need a stand-off for cleaning out gutters?
17.5' is the minimum length and I always like a little extra.
Lean it approximately 1' out from the wall for each 4' in height. It's an optimum angle and has something to do with vectors. I've had ladders at a 45 degree angle but I had stakes in the ground to prevent the base from slipping out.
One survival book I read said to avoid a 14' fall at all costs. At 35' ~half the people are dead and one unlucky person had permanent injuries from a 2' fall onto concrete.
You might want a safety harness and lanyard - I finally bought them for ladder work and tree work.
Thanks for that,I'll be looking for 2x12 rung ladder in woodworm free aluminium - ebay here I come... :D
aluminium woodworm - now there's an interesting little creature.
Since you apparently have never used long ladders , can you explain how you intend extending them up to your 17' soffit.
Woodworm free aluminium as opposed to woodworm infested wooden ladders of course.
Well I thought that with a suitable overlap they would still be 20 feet long,so i'd just lean them against the wall at an angle and they'd reach 17 feet up the wall?
Have I missed something?
Not really but pushing up the sliding ladder takes quite an effort. If you can find a set with a rope extension system it'll be a little easier. Just take care if buying second hand, the seller may be getting rid of something that he/she found unsuitable. Als ensure the rungs have flat tops since round tops are hell on the feet.
I'm guessing that the cheap and horrible ladders I'll likely end up with won't be too heavy or difficult to manage,and I'll look for flat rungs and check for damage and bodges before I hand over any money.
Thanks for the help. :)
Yes, but... If you get a 12' double ladder without a pulley, you can't extend it fully without climbing up it as you go - not recommended, especially for the faint-hearted!
A triple extension ladder is much easier to put up single handed. You can also take a section off and use it in the house, if you want. If you do buy a long double, you can extend the ladder on the ground with the foot close to the house and, with an assistant holding the foot down, 'walk' the ladder up from the top with your hands over your head.
I would recommend the use of a ladder stay if you're doing gutters - it saves you from leaning backwards or having to position the top of the ladder on the facia, just below the gutter (don't even think about leaning the ladder on the gutter!! :eek: ).
http://www.ebay.co.uk/itm/LADDER-ST...4685?pt=UK_H_G_Ladders_RL&hash=item19c42cad4d
I don't know of a safe way to test used ladders except maybe to have someone who weighs 2x or 3x what you weigh to climb it. :eek:
Why not just speak to the supplier?
I use these, find them an excellent company.
http://www.midlandladders.com/
