What size lintel for a 162cm wide doorway opening?
15 May 2013
I was going to go with 6ft but that would only mean 10cms overlap each end of the lintel. Should I be looking at a slightly longer one or will 10cm be ok? I read 150mm should be the minimum overlap.
Thankyou for your help
Thankyou. Do lintels have metal bars running through them or is it all concrete? I always assumed they had metal there for I couldnt cut through using a steel wheel.
A concrete lintel will have rebar in it, so when cutting you will require a multi cutting disc, but depending where purchased they may cut it down for you. And if you are lucky enough to live local to a pre-cast concrete manufacturer they should make bespoke sizes.
You can cut the pre stressed ones fine, they say make sure you cover the ends with mortar though.
The bearing is needed for shear strength of the beam and the compressive strength of what you're resting it on, so if you've not much above it then you don't need as much. But you might need calculations to satisfy building control so it may not be worth it.
I noticed they do ones without rebar in, the fire resistant ones. Obviously less strong, and probably harder to get hold of, but they exist.
A stone disk will cut steel. But not the other way around.
A 100mm bearing will be ok in most cases but as always, it depends on the loading.
Does anyone know where I can find the 1920mm or thereabouts lintels? I looked on the travis perkins website and couldnt find them.
Cheers
1800mm or 2100mm, so either make the hole smaller or cut one down.
Or just use 100mm bearings.
A diamond disk on an angle grinder/shtil saw cuts them fine.
Thanks guys, I just rang jewsons and they have a 2.1m in stock. On my way to collect it in an hour :)
