What to fill handle screw holes in wooden drawer fronts with?
27 Feb 2017
Essexshire
I’m having a go at 'upcycling' our kitchen dresser - just painting it and changing the handles but the handles I want to use on the drawer fronts have the spacing for the screws differently - 64mm instead of 100mm. I plan to fill the holes, paint the drawers and drill new holes to fit the new handles but what’s best to use to fill the holes with - ordinary polyfilla, wood filler or something else?
Edit: What about if I got some wooden dowels, banged them in (using wood glue) and sanded them down before painting? Would that work?
Id go with wooden dowels.
Undercoat then ready mixed fine filler if you want a great finish on your project.
Other way is 2 pack wood filler, but be neat and tidy when you use. Don't spread it around..
2 pack is resin and harder in a can...
Possibly the best you can do is make a bit off a feature, as they won't readily disappear end grain will take stain very differently and oak and beech have different colours and grains
what you can do is cut a plug from the inside surface off the drawer or hidden area to match up but needs a plug cutter the right size and wood with a matching grain
Not worried about end grain as the drawer fronts are being painted. Looks like wood plug, fine filler and paint it is then.
Seen the price of it! :eek:
There is that yes,
Wonder how it keeps in the tubes. I have done repairs with the standard 2 part ronseal stuff and it cracks at the filler/ wood junction.
Yes over kill for some knob holes o_O
as an aside
think off painting some surfaces and not others
for example doors and drawer fronts painted but the base top unpainted but the base sides painted so most off the base painted and perhaps on the top more unpainted
but fully a personal choice
