I am about to have a new retaining wall built that is going to be approx 20m long and it will be stepped down a bit in the middle section. The highest point on either end of the wall will be 900mm high and the lowest point towards the middle will be 700mm high.
The wall is going to be made of concrete blocks with the front facing part of the wall rendered. There will be proper drainage installed on the backside of the wall.
Can anyone recommend what would be best to lay and look good on the top of the wall? We were thinking that whatever gets laid on the top, it would be wider than the blocks so that we could run some LED strip lighting beneath the top section. We will be having a new porcelain tiled patio layed.
