what to use under door threshold
21 Jul 2010
Weymouth, Dorset
Just fitted a french door set and there is a narrow gap under the threshold. I think it's to narrow for expanding foam, so is there a gun applied sealant or mastic that will fill the gap nicely and also set hard.
When you say under the threshold, is this between the threshold and the cill?? This is generally for drainage unless your threshold is face drain... Do not seal
Put a pic up
Can't be too narrow for ex-foam.
We use the cheap throw-away cans and nozzles whereby you can actually flatten the nozzle or feed tube so that it fits into very slim gaps.
For this aplication ex-foam is second to none.
