I going to be putting a double RCD waterproof socket, outside at the front of the house (For plugging the hover in, to hover the car, & for the xmas lights at xmas), & just wanted to check what type of cable to use.
I thinking of using 2.5mm blue artic cable, as the cable will be clipped to the side wall of the house, about 3m from the ground, & the socket will be mounted appox. 2m off of the ground.
I was going to run the socket from a 16 amp MCB in the house CCU, Use 2.5mm blue artic cable to fed the socket, & next to the socket between the socket & the supply cable put a 1 gang MK Masterseal Grid Plus enclosure, with a 20 amp DP secret key Grid switch.(So that when the socket is not in use it, the supply to the socket can be turned off)
So would 2.5mm blue artic cable be ok to use, to fed this socket
