Hopefully a very simple question:
I am hoping to remove an old combi boiler that is now only used to supply hot water to a few taps, and replace it with a simple hot water cylinder/immersion heater combination. As the tank will be lower than the taps it will supply, and I can't see a way of having a high feeder tank, I was hoping to run it all at mains pressure. Is this ok, and can I just use a simple foam lagged type tank that stored hot water systems use? Is this what is meant by a 'direct' cylinder?
Thanks in advance for any help
