I am planning to have a doorway cut through from my hallway into the back half of a semi-integral garage which I intend to use for storage.
The wall in question is 9 inches thick, 2 thicknesses of brick with no cavity ( being an internal wall)
The wall is load bearing, supporting the upper story floor beams and, via a 4 1/2 inch upstairs wall, the roof of what I would say is a conventional 1960s 3 bedroom semi.
A builder has quoted (estimated) for the job in vague terms such as "a suitable lintel will be fitted"
I am aware that the door will need to be a self closing, half hour fire door, but for the door to fit in the wall space available it will need to be as narrow as practicable, i.e. 600 mm wide.
The point of this submission is that, even with this door width, extending the lintel by the recommended 150mm either side of the wall cutout will mean that one end will foul the vertical light switch conduit by about 30mm and I would prefer not to have the extra expense of moving this if possible.
So, finally, my question is - would the "suitable" lintel have to be 9 inches wide (deep?), the same as the wall thickness, or would it be sufficiently narrow to "tuck" behind the conduit which appears to be set into the wall to a depth of about 35 mm?
In summary then - could you advise me on a "suitable" lintel (size and material) for this project?
Thank you in advance to all those kind enough to reply.
